Is it possible to use REMAP_VALUES within Load Script to use it for the whole screen ?
  • Mar 31, 2023 6:30 PM UTC
  • 77 views
With REMAP_VALUES I was successfully able to remove an unwanted activity from my process flow. Now I am trying to use it with the load script to use it for the whole screen, but it doesn't work. Tried several syntax, but no success. Is there a way using it?
Forum|alt.badge.img+28
Hi Michael,
This is unfortunately not possible, since the Load Script section only handles Filters (which do not change the tabel fields). See this thread for related suggestions: remap of activities in the analysis settings does not work (celopeers.com).
