Is it possible to set Activity color in Process / Variant Explorer by formula? ...or by activity table field?It will be usefull in multilog scenario.Thanks,Alex.
  • Apr 27, 2022 10:27 AM UTC
  • 82 views
Forum|alt.badge.img+11
Is it possible to set Activity color in Process / Variant Explorer by formula? ...or by activity table field? It will be usefull in multilog scenario. Thanks, Alex.
katrin.kosto12
Level 1
Forum|alt.badge.img+14
Is the answer to this question already available? In the case of a 1000+ activities changing the color by formula would save a lot of time!
Hi Alex, please be informed that you can use Process Explorer KPIs ( https://docs.celonis.com/en/process-analytics/analysis-settings/process-explorer-kpis.html ) – define an activity KPI and set the colors in Thresholds based on a formula. You can then select the defined KPI from the Process Explorer to show the colors. Best regards, Rrezarta
