Is it possible to restrict users' access to dashboards by company code?
  • Feb 16, 2022 10:09 AM UTC
  • 98 views
rui.peixo
Level 2
We are a shared services company and we would like to provide differentiated access to users depending on client/company code.
For example:
User A Access: Company codes 1000 & 1001
User B Access: Only company code 1010
Is it possible?
Thanks
gabriel.okaba11
Hi Rui,
Yes, it is possible by using the Data Permissions. There is a step by step documentation in the Help Resources
[YourMotaEngilURL].celonis.cloud/help/display/CIBC/Data+Permissions
rui.peixo
Level 2
  • Level 2
  • Feb 22, 2022 10:41 AM UTC
Hi Gabriel,
Thank you so much.
I was focused on trying to find an access restriction at the dashboard level.
Greetings from Portugal
gabriel.okaba11
Hi Gabriel,
Thank you so much.
Hi Rui,
Exactly. If you create the restrictions on the Data Pool, it will reflect when user opens the Dashboard (i.e. User A Access: Company codes 1000 & 1001
User B Access: Only company code 1010)
