Is it possible to read the data of a table that we have extracted from a source system using celonis as a CSV file in the Machine Learning workbench using python.
  • Nov 13, 2023 4:08 PM UTC
  • 169 views
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
It is, you can get data from DM/DP transform it into python data frame and than export as CSV file.
Code Snippet:
celonis = get_celonis(permissions=False)
data_pool = celonis.data_integration.get_data_pools().find("X")
data_model = data_pool.get_data_models().find("X")
table = tables.find("X")
table.to_csv(index=False)
Rembember about permissions for workbench application being able to reach Data pool and data model, I'll late check if it fully works on Pycelonis 2.0.1 +
Mateusz Dudek
  • Nov 17, 2023 12:18 PM UTC
Hi Mateusz,
Is this code snippet applicable for pycelonis version 1.7.2?
