Is it possible to make values of a bar chart visible on views mode?
  • Mar 3, 2022 12:52 PM UTC
  • 38 views
Hi, i'm starting working with views, and I couldn't find any options or YAML code to visualize the values of a bar chart on views mode. I've been looking on Celonis cloud help as well but couldn't find it.
Any help would be appreciated.
Thanks!
Hi Alfredo, thank you for reaching out. Have you checked our documentation here: help.celonis.cloud/help/display/CIBC/Chart#Chart-BarChart where it shows how you can create a Bar Chart in Views, and the YAML configuration. We hope this helps with your request. Best regards, Lejla
