Is it possible to keep the filters with an overlay in the process explorer?
  • Nov 30, 2022 2:05 PM UTC
  • 180 views
sarina.somme
Level 5
Forum|alt.badge.img+11
Hi all,
I'm currently using the overlay functionality on the process explorer. We use this feature to open a profile view which shows the process explorer in a focus mode. As you can see in the screenshot if I filter the view and open the profile view via the process explorer the profile view is not filtered.
Screenshot
Is it possible to keep the filters from the view to the profile view via the process explorer?
Thanks and kind regards,
Sarina
abhishek.chatu14
Hi Sarina,
In your overlay option you should have something called carry filter, enable that you should be good to go
sarina.somme
Level 5
  • Level 5
  • Nov 30, 2022 7:23 PM UTC
Hi Sarina,
Hi Abhishek,
I know this option in a table but I‘m using the overlay function in the process explorer component to open a profile view and there I can‘t find the carry filter option.
Sarina
abhishek.chatu14
Hi Abhishek,
Sarina
Going through the documentation does not seem to be a way to preserve the filters in Profiler View while moving form Process Explorer. Would suggest to raise a ticket with Celonis to understand the same.
sarina.somme
Level 5
  • Level 5
  • Dec 1, 2022 9:39 AM UTC
Hi Abhishek,
Sarina
I will raise a ticket, thanks!
