Is it Possible to Integrate Celonis EMS with ARIS Connect ( BPM Suite ) ?
  • Nov 2, 2022 6:07 AM UTC
  • 214 views
Dear Experts ,
We wanted to understand the possibility of integrating Celonis EMS platform with third party BPM application like ARIS Connect to transfer discovered BPMN model from Celonis EMS to ARIS BPM application. Thanks in Advance.
Regards,
Navalan Veerapandian
There is no direct approach that I am aware of, however you can always download the BPMN model for Celonis and use it in ARIS and vice versa.
The steps you have to follow are as follows
  • Click on the General settings of your analysis
  • Check on allow bpmn export of process explorer
  • Export your BPMN model from process explorer (similar to exporting excel from OLAP table )
PS: The file is generated accordance with the BPMN 2.0 standard.
abhishek.chatu14
  • Nov 4, 2022 8:42 AM UTC
Hi Abhishek,
Thank you for your Reply.
mark.b.olive
Level 2
Forum|alt.badge.img+10
Hi Abhishek,
Would you know if the possibility to run the BPMN extract using Pycelonis?
My idea is that, using the ML Workbench, I will extract the BPMN on a specific Process/Variant Explorer Analysis and established an API call to push the BPMN file.
T&R,
Mark
