Is it possible to have the data set of the demos on TryCelonis?
  • Nov 29, 2021 6:12 AM UTC
  • 185 views
Hi All, may I know is it possible to get the data set used in the Procurement TryCelonis Demo?
That will be really helpful when we let our users to know what exactly they may need to provide in order to perform process mining.
Thank you!
Best answer by gabriel.okaba11
Hello David,
As this is a more common request during the implementation, you could install the Procurement App in your Celonis IBM Sandbox from the EMS Store and then go to Event Collection to check the specific tables.
Go to https://partners.celonis.com/ ->Resources->Celonis Sandbox
Gabriel
gabriel.okaba11
Hello David,
Gabriel
  • Nov 30, 2021 6:16 AM UTC
Hi @gabriel.okaba11
Thanks for your reply! Yet i do not have the admin right to install the apps there, would you please advise who should I reach out to for that?
David
gabriel.okaba11
Hi @gabriel.okaba11
David
Hi @david.liu13 ,
this is managed by someone from IBM side. You don't need the full admin rights to install it. I believe the easiest route would be to check with other IBM colleagues. If it does not work, you can book a time slot with a Celonis Ecosystem Consultant through the same platform.
best,
Gabriel
