Is it possible to execute a skill with a kpi value?
  • Sep 27, 2023 9:11 AM UTC
  • 49 views
sarina.somme
Level 5
Forum|alt.badge.img+11
Hi all,
I would like to execute a skill with two variables. Is it possible to set the value of one variable with a kpi from the knowledge model?
Thanks and kind regards,
Sarina
Hi Sarina, thank you for reaching out! To be able to help further could you please create a case for customer support on celopeers and provide more information regarding your request what is your case where you are trying to use it etc. Best regards, Rrezarta
