Is it possible to check in a "if-clause (case when clause)" whether a specific drop down selection is used or not?
  • Oct 18, 2022 8:19 AM UTC
  • 5 replies
  • 154 views
For exmaple: There is a dropdown selection which includes different vendors. I want to create an column chart of the first 5 vendors if no selection of a specific vendor is used. On the other hand if a vendor is selected in a dropdown menu i want to display only that vendor in the said column chart.
Thank you!
harish.c.j
Level 5
  • Level 5
  • Oct 18, 2022 9:56 AM UTC
Yes, you can assign the dropdown selection to a variable and use that variable in case when clause in the column chart.
  • Oct 18, 2022 12:13 PM UTC
Thank you for your answer. And how can I integrate the statement CASE WHEN "drop down is empty" THEN...
is there a syntax for it or do I miss something here?
Best regards
harish.c.j
Level 5
  • Level 5
  • Oct 18, 2022 12:21 PM UTC
Best regards
case when <%variable> is null then ... end
  • Oct 18, 2022 12:55 PM UTC
Unfortunately this doesnt work. An error occurs when no value is selected in the dropdown menu. The error disappears after I select a value.
harish.c.j
Level 5
  • Level 5
  • Oct 19, 2022 6:52 AM UTC
Sorry, please ignore earlier reply.
Below method will work, but it will apply the filter to the entire analysis and not to a specific component.
  1. Limit the number of in column chart to 5 and add sorting appropriately
  2. Dimension should be the vendor column
  3. You have to add dropdown (under selection components) component (NOT button dropdown under design components) and dropdown items should be the vendor column
