Is it possible to change navigation panel to distinguish between environments?
  • May 10, 2023 9:35 AM UTC
  • 109 views
karol.trzci12
Level 4
I have a question related to some quality of life changes in UI.
We have two Celonis environments PROD and QA. I know that I can see the env in which I am by looking at URL, but I would like to have some more visual ability to distinguish between the two. Is it possible to change the navigation bar (I believe that what it is called - see the image below) to a different color? Or to make some other change to parts of UI that are always visible in order to have that visual difference at a glance of an eye?
Navigation barThank you,
Karol
Hi Karol,
Thank you for logging this Enhancement Request.
We greatly appreciate your feedback and have recently modified the process for collecting your input to ensure that we provide you with the best experience possible. Going forward, please create the feature request through Celopeers or work with your Account Contact, who will log all the details of your request.
Thank you for your ongoing partnership and feedback.
Blenda
