Is it possible to automatically upload file to data pool using Action Flow?
  • Dec 8, 2022 11:07 AM UTC
  • 158 views
Currently, my client have a list of user IDs that we update weekly and upload manually. I would like to automate this process. We are currently considering these two methods.
1. Pycelonis
Creating a script using the Pycelonis method maybe is a good idea and I found this answer.
upload parquet file and refresh data modell automatically (celopeers.com)
2. Action Flow
I have not looked into this in detail, but I am wondering if it is possible to use a module such as HTTP request to upload a file, for example.
I would appreciate any advice you can give me on the above, especially the second one.
Yes it is possible, you can check the following to get started
https://docs.celonis.com/en/create-and-push-csv-to-data-integration.html
abhishek.chatu14
