Is it possible to add process rules in the conformance checking analysis?
  • Jul 22, 2024 8:19 AM UTC
  • 116 views
I am doing conformance analysis and i want to add some process rules to be considered in the analysis.
For example: If the PO is of type X, then it does not need a PR. Other PO types need a PR
Another example: for all POs in company code XXX, the activity 'Receive Order Confirmation' is not required.
In the conformance sheet we can only add KPIs and add violations to allow list, but there is no option to customize these violations to focus on certain cases, or add other process rules to the analysis.
I'd appreciate it if there is any way to come over this!
Thanks,
Nourhan
abhishek.chatu14
This may not be possible with the conformance checking analysis
The way to handle this is to create mutiple sheets of conformance and adding these filters as a sheet filter.
You will have seprate conformacnce models for each PO type you are refreing to with diffrent models.
This can be done in Process Adherence Manager, look at the following link for more information
Setting the data scope of your baseline model (celonis.com)
