Is it able to copy data pool with data?
  • Mar 24, 2023 12:40 AM UTC
  • 93 views
Hi all,
I'm looking for way to copy data pool with its data, I found copy function of data pool but if I push that it only contains data connection, data job, and data model, not its uploaded data.
Is it able to include original data to copy environment?
Hi Jumbo, hope you're doing well.
You can open an analysis, create an OLAP with all the columns, and generate a CSV Data Export, and then re-upload it.
Many thanks,
