Is data stored in AWS or Azure? (There's one post that says its hosted in AWS and another that says its hosted in Azure)
  • Mar 6, 2023 6:45 PM UTC
  • 200 views
kay.kaspe
Level 3
  • Mar 7, 2023 7:08 AM UTC
Both answers are correct. See also https://docs.celonis.com/en/data-security.html#UUID-129a363e-a425-57b7-5d49-70006e55f234_id_DataSecurity-Whereisthedatastored
Where the data is stored depends on the cluster.
In the documentation, there are several pages where the IP addresses are listed (https://docs.celonis.com/en/how-do-i-set-up-a-database-connection-.html#UUID-00c43428-47e3-16f8-5c88-4a250b6c6cf1_id_HowdoIsetupadatabaseconnection-EMSIPaddressesdependingonthecluster).
From memory, for the EU clusters they are
EU-1 : AWS
EU-2 : Azure
EU-3 : Azure
EU-4 : AWS
EU-5 : AWS
You could check this, for example with https://ipgeolocation.io/
  • Mar 7, 2023 12:19 PM UTC
Thank You very much!
  • Mar 7, 2023 12:29 PM UTC
Celonis clouds are either on AWS or Azure, if you like to know which cloud specifically you can contact Celonis directly and ask the cluster you are running on (eu-1, eu-2, etc.) is on Azure or AWS. I only know eu-3 server is running on Azure.
