Is anyone know, how to configure KPI Parameters in Knowledge model KPI's and YAML code.?If yes can you please let me know the syntax in PQL.Thanks in advance..!
  • Nov 29, 2023 7:38 PM UTC
  • 95 views
Is anyone know, how to configure KPI Parameters in Knowledge model KPI's and YAML code.? If yes can you please let me know the syntax in PQL. Thanks in advance..!
Forum|alt.badge.img+28
Hi @manish.srima11,
You can find how to define KPIs in your knowledge model in the docs: Knowledge Model - KPI (celonis.com)
Next to that, the syntax on how to use them in View components using YAML can be found here: https://docs.celonis.com/en/knowledge-model---kpi.html#UUID-8244f61e-18b5-7bee-bf4a-c5bd65b6d3d0_id_KMKPIs-ParametrisedKPIsYAML
I hope this helps!
