Input checkbox component in views
  • Nov 19, 2022 10:24 AM UTC
  • 136 views
I’m trying to configure an input checkbox component with a chart/kpi
I’m not getting to configure it correctly. I’m unable to use sharefilters attribute in kpi list
any help on configuring this component will be helpful
thank you
abhishek.chatu14
Is this what you are looking for ?
  • Nov 24, 2022 5:16 PM UTC
Yes @Abhishek Chaturvedi
but I configured in the same way
but the value doesn’t change when the input checkbox is checked
abhishek.chatu14
Have you created the variable as well ?
  • Level 7
  • Jul 11, 2023 6:53 PM UTC
Yes @Abhishek Chaturvedi I have created the variable as well.
