Input Box (Date) - How to use the output?
  • Sep 6, 2023 3:10 PM UTC
  • 251 views
Hi everyone,
I want to use an input box in a view so users can filter a specific table using a runtime variable. When using the input box and setting it to type date, the output is something like 1694728800000. This is saved in a runtime variable, which I am using in a filter for that specific table. However, I couldn't find a way to make the formular work.
Example formular: FILTER EKPO.AEDAT = ${{runtime_variable}}
where ${{runtime_variable}} is 1694728800000.
Maybe someone can help out with the correct conversion to make use of the date from the input box.
Best regards
Aram
What you are missing is {t 1694728800000}, refer to the following for more details
https://www.celopeers.com/s/question/0D50700002krk4cCAA/what-does-t-946771200000-refer-to-what-is-returned-as-op-for-the-above-part-in-the-pql-statement-case-when-table1column1-in-t-946771200000-t-1009756800000-t-1245145600000-then-table1column1-else-null-end?language=en_US
It is not very clear from you question if you have figured out the runtime variable and input box bit but assuming you have try the following
FILTER EKPO.AEDAT = {t ${{runtime_variable}} };
Hope this helps!
abhishek.chatu14
Hope this helps!
  • Level 3
  • Sep 11, 2023 1:44 PM UTC
Worked perfectly, thank you!
Any idea how I could now show the selected date as a headline in a view?
TO_STRING( {t ${{runtime_variable}} }, FORMAT ( '%d.%m.%Y ' ) )
I tried this in a variable in the KM but got an error when referencing that variable in the view. And for a variable in the view itself I just get the plain text without the proper calculation.
