In View section how to add colors to table , charts And graphs.?
  • Jul 10, 2023 8:38 AM UTC
  • 234 views
sanati.dines
Level 3
Forum|alt.badge.img+2
I have done to create tables and charts in view but how to add table border margin colors and in charts & graphs section how to add in different colors.
  • Level 7
  • Jul 10, 2023 2:27 PM UTC
Hi @sanati.dines , in Views for charts you can choose different colors from the color scheme available in visual or code editor
using Visual editor: click on General settings at the top right -> under the Color Scheme for Layers click on the dropdown and choose the desired colours.
To add colours to Table component in views:
you first need to create a custom object in Knowledge Model by defining the display details you need.
Refer Display Rules content in help resource for complete understanding.
HTH
  • Jul 14, 2023 12:06 PM UTC
HTH
can't we customize color, which we want?
  • Level 7
  • Jul 14, 2023 7:31 PM UTC
@uma.penme
you can choose from one of the available color options in section Chart customisation option
https://docs.celonis.com/en/charts.html
