In Quickstart the .xes upload, does not work. Any solutions?
  • Aug 21, 2023 1:07 PM UTC
  • 111 views
The status of the upload stays on "uploading files" forever. I know of the 1GB upload limit and have tried it with several different .xes files and none work.
abhishek.chatu14
Have you tried breaking the file into smaller chunks and uploading ?
  • Aug 21, 2023 2:05 PM UTC
No, but I don't think that will make a difference, since I tried it with very small files as well (less than 1MB) and they do not work. So breaking my 500MB file into smaller chunks is most likely not going to do much.
