IML function error in Get Rows action flow trigger
  • Aug 1, 2025 12:18 PM UTC
  • 156 views
herique.sarme
Level 4
Forum|alt.badge.img+9
Every ‘Get Row’ module suddenly stopped working, all at the same time… Has anyone ever seem this error message before? What does it mean? How can I prevent it from happening again?
Error: Cannot initialize the scenario because of the reason 'Failed to compile IML function 'functionToDeleteSecond'. Unexpected identifier 'is''
  • Celonaut
  • Aug 4, 2025 9:08 AM UTC
Hello Herique, hope you are doing well.
The error means that there is a function that was developed by developers that contains code that throws error while trying to compile the Celonis App but the functions is no longer active so there is no reason for it to happen again. So please check once and confirm it again to me if you are stil facing the same issue. Many thanks!
