Identity didnt work in celonis sql?
  • Apr 7, 2022 4:52 AM UTC
  • 47 views
I want to create a table which will auto increment the id. Identity is not working, do we have any other solution?
CREATE TABLE production_categories (
    category_id INT IDENTITY (1, 1) PRIMARY KEY,
    category_name VARCHAR (255) NOT NULL
Hi Amit, Many thanks for reaching out. Could you please try the following: CREATE TABLE production_categories ( category_id IDENTITY (1, 1) PRIMARY KEY, category_name VARCHAR (255) NOT NULL ); Kindly let us know if it will work? Thank you for your patience, understanding and collaboration in this matter. Best regards, Valmira Abdiu
