IBC Data Jobs Transformation Suggestion
  • Jul 12, 2019 8:13 PM UTC
  • 43 views
When working with data jobs transformations; specifically going through them to edit a field on multiple transformations, it would be nice that once you make an edit, save the transformation, then have the ability to click on a Previous or Next button to move to the transformation before or after the current one without having to go first click on the back button, then hunt down the next transformation that you want. Ive included a screenshot of what Im suggesting. Thanks! -Dallas PrevNextTransformation.png1672776 58 KB
Hi Dallas, Thank you very much for your input and your clear explanation. Navigating between transformations without leaving them is actually a feature we already have on the roadmap. Best regards, Leonid
