Iam not able to see some BELNR's in BKPF which are available in BSEG and iam applying the same filter GJAHR> 2021 in both tables. What is the solution for this?
  • May 24, 2022 5:39 PM UTC
  • 42 views
Forum|alt.badge.img+10
Hi Guturi,
here are some basic perspectives to be checked.
  1. Are the two tables connected via primary keys in Data Model?
  2. Do you intend to show up several columns from both tables in a single component?
  3. Is the data actually extracted from the same fiscal year? The number range comes to the head every fiscal year, unlike SD/MM documents.
As far as I know, it is possible for SAP to have BKPF without BSEG, but not the opposite. Hope you find some clues for solutions.
