I would like to know more about Signal Link Explorer
  • May 29, 2023 7:57 PM UTC
  • 175 views
I am trying to understand how can I use a Signal Link Explorer (SLE) component in a view.
I found in Celonis documentation orientation about Network Explorer (NE), even it is mentioned that exists SLE, but I didn't find further information about it.
I would like to access an explanation about the YAML components of it.
I found it applied at Inventory Management app and I would like to use it, but I didn't understand how to get there.
I hope someone is able to help me on it.
andré.tafur
Level 8
Forum|alt.badge.img+19
Hello Marcia,
I'm also looking for more information on Signal Link as I see it changing.
Previously, to create a Network Explorer with Signal Link you had to mark the Nodes and Edges tables with a special option from Data Integration in the Data Model section, for this you had to request access to this option through a support ticket.
Today I went through the documentation and it seems that it has changed. There is now "OBJECT_LINK" which is used to link objects (and I believe to create graphs like network explorer) and "SIGNAL_LINK" which is now used to link activities from different activity tables, this change comes from the object centric process mining.
I share the documentation that I found, it can help you understand the logic of operation and I recommend you request a support ticket to enable OBJECT LINK and SIGNAL LINK and you can try it.
Please, if you have any additional information that was provided to you, could you share it?
https://docs.celonis.com/en/object-link.html#UUID-71d3cdb3-fd41-c2b9-09f2-d44b7fd8db3a
Best regards.
  • Jun 13, 2023 1:10 PM UTC
Hello André!
I was digging around here on Celopeers, and I ended up finding information about a Celonis Hackathon, on this topic, which took place in 2021, it has 9 items to download, among them there is a guide, I performed the step by step and managed to generate the signal link explorer as I expected, from it it was easy to understand the logic. Hope it helps you too.
Follow the link: https://www.celopeers.com/s/feed/0D50700000XiqFHCAZ?language=en_US
Marcia
andré.tafur
Level 8
Hello André!
Marcia
Thank you Marcia!
This guide was very helpful 😊
Best regards.
André
