I would like to get the throughput time between specific activities, averaged per unit.
  • May 22, 2024 8:29 AM UTC
  • 230 views
How can we calculate the average throughput time per unit without errors?
imageーー
AVG(
   CALC_THROUGHPUT (
   FIRST_OCCURRENCE [ '伝票登録画面表示' ]
  TO FIRST_OCCURRENCE [ '伝票保存' ]
  , REMAP_TIMESTAMPS ("t_Activity"."日時", MINUTES ) )
ーー
ーーErrormessage​ーー
The aggregation function AVG is applied on a column from table "t_Case" which has a 1:N relationship to the common table "t_Activity". This means that one input value can contribute to the aggregation result multiple times. For more information search for "Join functionality" in PQL documentation.
ーーErrormessage​ーー
Forum|alt.badge.img+7
Hi Ishiduka!
Try this:
PU_AVG( DOMAIN_TABLE("Case_Table"."_CASE_KEY"),
CALC_THROUGHPUT (
FIRST_OCCURRENCE [ 'Activity1' ]
TO FIRST_OCCURRENCE [ 'Activity2' ]
, REMAP_TIMESTAMPS ("Activity_Table"."EVENTTIME", MINUTES ) )
  • May 31, 2024 7:48 AM UTC
Thank you so much.
I created the PQL as you said. When I did so, the throughput time per record was displayed.
What I want to display is the throughput per unit number.
How should I describe it?
Hi Ishiduka!
Could you provide more info on what table your unit number comes from and the relationship of this table to the activity table?
