I would like to filter (select) certain activities flow, however instead of the activities appearing in the "Activity Selection" or "Process flow selection" sections, they are appearing in the "Attribute selection" tab/section.
  • Aug 7, 2023 2:50 PM UTC
  • 115 views
My hypothesis is because of how the data is setup but wanted to understand why this is happening and how we can fix it.
Hi Pavan, thank you for reaching out. Are you still having this issue? Please note that attribute selection allows you to select based on single values from the tables in your data model whereas activity selection allows you to select cases based on the activities they flow through, start, or end with. For more, please check our help page: https://docs.celonis.com/en/selections-in-analysis-ui.html#UUID-126cf063-13f3-cd91-a7d9-206271f2cd98 Best Regards, Blenda
