i want to use conditional filter Null values in "load script" section by "Case When "
  • Jul 26, 2022 2:33 PM UTC
  • 113 views
Hi @ALL
 i try to do smth like this. one dynamic filter should execute the NULL values in the table.
FILTER "table". "column" = CASE WHEN <%=option1%> = 'abc' THEN NULL END;
all other filters work but i cannot return null values from the same table. I have tried this formula
FILTER "table". "column" = CASE WHEN <%=option1%> = 'abc' THEN Filter_TO_NULL("table". "column") END;
but when i have tested, i realized that i did bring up all values but not Null values from table. Does anyone have an idea?
Forum|alt.badge.img+2
Can you try the following? FILTER 1 = CASE WHEN <%=option1%> = 'abc' THEN ISNULL("table"."column") ELSE 1 END; This filter should operate with the following rules: If option1 = 'abc', only records where table.column is null should show up. if option1 does not = 'abc', it will show all records.
