i want to use conditional filter in "load script" section by "Case When "
  • Jul 8, 2022 11:06 PM UTC
  • 6 replies
  • 197 views
How can I set conditional filter in load script page? I have tried Case When, but it gives me error. Is there anyone who has suggestions?
Filter "xx"."yy" = <%= option1%> (it works)
i want to do multiple conditions like that in component filter
case when <%=option1> = 'a' than Filter "xx"."yy" = 'value' ;
case when <%=option1> = 'b' 'than Filter "xx"."yy" = 'value2' end
Is there any way to add conditional filter in the component filter section?
Best answer by tony.hoang11
Can you try reordering it to something like this? FILTER "xx"."yy" = CASE WHEN <%=option1%> = 'a' THEN 'value' WHEN <%=option1%> = 'b' THEN 'value2' END ;
  • Jul 11, 2022 2:19 PM UTC
I made some test, but I couldn't get the results.
Nevertheless here my filter. Maybe it will give you some ideas
FILTER
CASE WHEN "CV_POLIZA"."COD_RAMO" = 111
THEN
CASE WHEN PU_COUNT(CONSTANT(),"CV_POLIZA"."NUM_POLIZA") > 1 THEN 1
ELSE 0
ELSE 0
>= 1
OR
CASE WHEN "CV_POLIZA"."COD_RAMO" = 110
THEN
CASE WHEN "CV_POLIZA"."NUM_POLIZA"= 'POL-04' THEN 1
ELSE 0
ELSE 0
>= 1
erik.zwick12
Maybe instead of using a component filter this could be achieved in the component itself using nested case when statements. Has that been tried yet?
  • Jul 14, 2022 9:32 PM UTC
yes , i have tried, but the problem is i am using dynamic filter, and it doesn't return the exact keyword in the table.
Forum|alt.badge.img+2
  • Level 0
  • Answer
  • Jul 15, 2022 9:40 PM UTC
  • Jul 21, 2022 1:49 AM UTC
yes, it works properly. thank you
  • Jul 23, 2022 6:43 AM UTC
Hi @ALL
let me update my question.
one the dynamic filter should execute the null values in the table.
FILTER "table". "column" = CASE WHEN <%=option1%> = 'abc' THEN NULL END;
all other filters work but i cannot return null values from same table. I have have tried this formula
FILTER "table". "column" = CASE WHEN <%=option1%> = 'abc' THEN Filter_TO_NULL("table". "column") END;
but when i have tested, i saw that i didn't bring up all null values from table. Does anyone have an idea?
