I want to know how many activities occurred for each group
  • May 16, 2023 9:59 AM UTC
  • 161 views
I have a category table, table2 and Activity table
relation is category(N) - table2(1) - Activity(N)
in a bar chart, I want to show group from category table and count of activities for each group. I’m getting no common table error while configuring a component.
how to fix this for a relationship N:1:N
andré.tafur
Level 8
Forum|alt.badge.img+19
Hello Preethi,
Try to use a PQL combining the PU and BIND functions, I am not clear which is the query you are using but I leave you an example of how you could solve your problem.
PU_SUM("category_table", BIND("table2", "activity_table"."activities")) )
I hope it helps you
  • May 16, 2023 4:05 PM UTC
Hello Preethi,
I hope it helps you
Hi @andré.tafur , thank you
but this way also I’m getting error that there is no relation between table2 and activity table
but there is 1:N relation between them
