I want to implement merge or join of two tables inside analyses (using code editor) on the onprem environment
  • Oct 3, 2023 6:20 PM UTC
  • 127 views
If we have 2 tables with category1 and category2 as their data respectively
How to get C table with all the fields from category 1 and category 2 ?
note : tables are not connected with any case key
abhishek.chatu14
Would require more information, are the tables connected in the first place ? If not the same is not possible.
What are you trying to do when you say merge inside analysis are we displaying data in a single olap table ?
How are they connected based on that you could use a PU or BIND function ?
Bind or PU
You could also look at Domain Table for the same.
