I want to add days to a date in vertica SQL in transformations.I have tried using DATEADD and TIMESTAMPADD, both are showing permission denied.Please help how can i achieve this.
  • Jul 10, 2024 12:37 PM UTC
  • 238 views
gauri.pai11
Level 3
Forum|alt.badge.img+3
I want to add days to a date in vertica SQL in transformations. I have tried using DATEADD and TIMESTAMPADD, both are showing permission denied. Please help how can i achieve this.
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
TIMESTAMPADD works fine for me. Probably you messed up the syntax.
Adding a screenshots of something 'not working' usually make easier to help.
Code:
SELECT TIMESTAMPADD (DD, 2, (SELECT TRUNC((CURRENT_TIMESTAMP), 'MM'))),
 TRUNC((CURRENT_TIMESTAMP), 'MM') AS Initial_timestam ;
Documentation: TIMESTAMPADD (vertica.com)
Screenshot:
Mark as best answer if helped, and let us know if that worked :)
Mateusz Dudek
Hello, U can try something like this, this will work.
To add days: TIMESTAMPADD('day',1,GETDATE())
To minus days: TIMESTAMPADD('day',-1,GETDATE())
kandi.naidu
Level 7
  • Level 7
  • Jul 17, 2024 10:09 AM UTC
Hi @chaithanya.reddy11 ,
If you're getting TIMESTAMPADD is not supported while running the syntax in transformation. Please raise a feature request. Valid Engineer will add TIMESTAMPADD in your environment.
