I think the root cause analysis in GUI (Conformance) only performs the first level of root cause, but is it possible to perform a multi-dimensional root cause analysis (second and third level) using Pycelonis? If so, please let me know how to do it.
  • May 18, 2022 12:57 AM UTC
  • 92 views
Forum|alt.badge.img+14
I am also trying the Root cause analysis described in the Pycelonis tutorial from the top.
https://celonis.github.io/pycelonis/1.6.0/tutorials/root_cause_analysis/01_Root_Cause_Analysis_Tutorial/
At the data model connection, I get a NameError when I specify a data model.
I'm copying and pasting the data model ID, so I don't think it's wrong, but am I missing some operation?
The data model attempts to use this
  • May 18, 2022 6:48 AM UTC
Dear Sasaki-san,
Regarding second issue you said, could you check if celonis.datamodels returns list including your data model ? If empty list is returned, it may be your API key does not have appropriate permissions.
Regarding first question, I guess you will filter data by first root cause attribute, then try root cause analysis to find second root cause etc.
Kazuhiko
  • Level 1
  • May 18, 2022 8:22 AM UTC
Hello Takata-san
Thanks for the reply.
I tried "Celonis.datamodels" as advised and realized that the id was wrong.
So it was not datamodel id = datamodel key, but something else.
Regarding multidimensionality, if I want to do what you advised (filter the data with the first root cause attribute and do a root cause analysis with the other attributes as multidimensional) in Workbench, do I need to write the code from scratch myself?
Or is it already available on Git hub or Pycelonis tutorials?
  • May 18, 2022 8:31 AM UTC
Dear Sasaki-san,
You can use ID or name in find method, so let's try by name at first.
Regarding multi-dimensional root cause analysis, I imagine I can use standard Analysis (Conformance) and use 'Load script' to filter data in Analysis.
If you find EKPO.BUKRS = 1000 is the first root cause, then you will set FILTER EKPO.BUKRS = 1000 in Load script and try second root cause.
Kazuhiko
