I'm currently creating a class based around process mining and want to give the students a final project to do in Celonis and am looking for a good data set to use. Does anyone have a recommendation?
  • Apr 6, 2022 11:56 PM UTC
  • 76 views
The students are a mixture of engineering and logistics majors and this is their first experience with process mining and Celonis.
Forum|alt.badge.img+27
Hi @1460048712,
At the data.4tu.nl website (which is collaboration of the 4 technical universities in the Netherlands), you can find event logs that are ready to use. Some of these logs are also used for the BPI Challenges - IEEE Task Force on Process Mining (tf-pm.org). The following link shows the results for the search term 'event log':
4TU.ResearchData - Search
Cheers,
