I have 2 columns with timestamps and I need difference between those timestamps as 3rd column and I need a single KPI as avg(3rd Column).Can anyone suggest the pql formula for that..?
  • Mar 14, 2024 2:45 PM UTC
  • 5 replies
  • 130 views
Forum|alt.badge.img+7
I have 2 columns with timestamps and I need difference between those timestamps as 3rd column and I need a single KPI as avg(3rd Column). Can anyone suggest the pql formula for that..?
dennis.pflug
for the 3rd column you can make use of one of those DateTime Difference Functions: DateTime Difference (celonis.com)
e.g like DAYS_BETWEEN or DATEDIFF
And you KPI can be calculated like this:
AVG(DAYS_BETWEEN(
     PU_FIRST(CASE_TABLE, TABLE.COLUMN1),
     PU_LAST(CASE_TABLE, TABLE.COLUMN2)
BR
Dennis
AVG(DAYS_BETWEEN(
BR
Dennis
Hi Dennis,
Both timestamps are in case table then the formula which you suggested will not work right.
is there any other formula for that..?
dennis.pflug
Ok in this case I would try to make use of an DOMAIN_TABLE: DOMAIN_TABLE (celonis.com)
e.g:
AVG(DAYS_BETWEEN(
   PU_FIRST(DOMAIN_TABLE(CASE_TABLE._CASE_KEY), CASE_TABLE.COLUMN1),
   PU_LAST(DOMAIN_TABLE(CASE_TABLE._CASE_KEY), CASE_TABLE.COLUMN2)
BR
Dennis
e.g:
AVG(DAYS_BETWEEN(
BR
Dennis
Hi Dennis,
The use of DOMAIN_TABLE has worked to solve that.
Thank you so much for your time.
dennis.pflug
Hi Dennis,
You're welcome. :)
