i cannot found fundamental process mining in business analysis what can i do
  • Jun 30, 2024 4:44 AM UTC
  • 189 views
mateusz.dudek14
Level 11
Forum|alt.badge.img+10
If you want to get any good answer, please formulate your problem clearly...
What do you mean by 'fundamental process mining'? The most basic process mining visualisations are Process explorer, Variant explorer - at least in business analysis in a form of sheet (Process explorer) or single components to be placed on a empty sheet (both).
If you don't know how to create it, use it, or modify - I would recommend doing a basic Celonis training on Celonis academy. One of the recommended would be https://academy.celonis.com/learn/learning-path/review-and-interpret-analyses
Mateusz Dudek
rita.kiss12
Level 7
Forum|alt.badge.img+3
  • Level 7
  • Jul 1, 2024 11:47 AM UTC
If you mean the fundamentals of process mining training in Celonis Academy, I think this is the one: https://academy.celonis.com/learning-paths/process-mining-from-theory-to-execution It just got renamed.
