I can't seem to enroll in a session, due to a small lag in the system.
  • Mar 16, 2022 11:35 AM UTC
  • 33 views
The session I want to enroll in, has a link I cannot press because it is hidden behind the screen of another course
Can you provide a screenshot/link?
As one-time workaround i would just right click with mouse on that element and select "Inspect" (or "inspect element") then double click on on the line that's selected, and change visiblility by clicking on checkbox (Tha's how it can be done in firefox).
That can seem to be a little bit technical, but you'll get possibility to enroll without waiting for change in the website layout.
I've showed a solution on firefox browser but for other it should be similar, changes will disapear after refreshing the site.
It only affect the way you're looking on the site, adblocks are working same way.
obrazobraz
Mateusz Dudek
