I am trying to access transformation scripts from ML worbench with pycelonis 2.6 . But i am not able to fetch SQL scripts from transformation jobs which belongs to a template with visibility type protected. How to open the protected from task te
  • Aug 6, 2023 2:32 PM UTC
  • 158 views
I am trying to access transformation scripts from ML worbench with pycelonis 2.6 . But i am not able to fetch SQL scripts from transformation jobs which belongs to a template with visibility type protected. How to open the protected from task templates?
abhishek.chatu14
Hi Sayan,
I have faced the same issue don't really have a solution for the same, however the workaround would be to copy paste scripts into new transformation jobs.
This could be because theses scripts are Celonis assets , you can raise a ticket with Celonis to help you with the same.
  • Aug 7, 2023 9:29 AM UTC
😌 copy pasting is the tedious job. Thats why thought of directly fetching the script with pycelonis.
Yaa, will raise a ticket for this to make them open.
Dhilip Kumar Vijayan
Level 1
Dear Team - I m on the same boat, any updates or solution from Celonis?
