I am looking to get a basic difference between 2 columns?
  • Aug 16, 2021 5:57 PM UTC
  • 79 views
Forum|alt.badge.img+7
Column 1 has values where the KPI is as such for a company 1 (after clicking calculate shares in percentage checkbox):
SUM(Days related to certain case numbers)/COUNT(DISTINCT (No. of cases))
Column 2 has values where the KPI is as such for a certain company 2 (after clicking calculate shares in percentage checkbox):
Column 3 has the difference
Based on what I saw the values for column 1 and 2 are read in correctly, but the difference in column three is wrong
Any suggestions on this would really be appreciated
Found an answer!
I used the GLOBAL function around the count to get the specific count for that particular case
Using that allowed be to get the correct difference between the 2 columns
SUM(Days related to certain case numbers)/GLOBAL(COUNT(DISTINCT (No. of cases)))
