How to use the D3 Formatting to align a single column?
  • May 22, 2024 8:50 AM UTC
  • 157 views
milan.eric
Level 6
Hey,
I cant really find a lot of information about how to use the D3 Format for columns.
imageHow do I align a single column to the center here?
It says to use "^" but I cant implement it.
Thanks!
Forum|alt.badge.img+7
Hi Milan,
Could you please provide more details on what you’re trying to achieve so we can further assist you?
milan.eric
Level 6
  • Level 6
  • Jun 12, 2024 12:46 PM UTC
Hi Milan,
Hey Paulina,
I am looking for a way to manipulate columns. For example I have an OLAP-table with a column "Menge":image
Now I want the numbers inside this column to be aligned in the middle. Like you can align things in Excel to the left, right, middle.
Sadly I dont really understand how I fil the "Formatting formula"-field to achieve this.
I hope it became more clear, thanks!
Hi Milan,
You can align the text of a column to the center in an OLAP table by selecting "Text Area Options" in the dropdown on top of the setting and then selecting the appropriate alignment option from the options displayed:
I hope this was clear.
Paulina
