How to use 'SAP Demo' connection listed under 'New Data Connection' in Data Pools in Event collection module.
  • Sep 16, 2021 10:43 PM UTC
  • 92 views
I'm trying to use Celonis provided pre-configured demo application in TryCelonis. During the creation of data pool, it asked to create Data connection. From the list of available connections there is one connection named as 'SAP Demo'.
Is this build in connector to connect with demo data related to SAP? When i tired to use this connection, it pre populated connection details like Host, client, systemNumber and user id. In order to complete connection, it need password and i'm not able to find it anywhere in any documentation. I'm not sure it is correct approach and i'm making correction assumption about 'SAP Demo' data connection.
I'm trying to setup an environment from demo data without creating actual connector with SAP. Is this possible? if I do not specify data connection, then i'm unable to get 'Data model' object from PyCelonis for the analysis that is using that data model.
Any help shall be greatly appreciated.
  • Level 7
  • Sep 20, 2021 10:31 AM UTC
Hi Obaid Ullalh,
Appreciate if you can share the Screen shot with error, Hope we can help you ?
BR/VM
I'd like to know about 'SAP Demo' connection. What is the purpose of this connection? Does it connect to some demo data? More importantly, i'm interested to how to use any connector without pulling data from any other source and instead use Celonois provided demo data.
I'm able to use application from 'EMS store' that uses demo data but whenever i try to programmatically access data model for those applications i'm getting error. I want to use Celonis provided analysis from EMS store and access it data model.
