How to use OR in numerator and denominator while writing KPI in ratio format
  • Oct 21, 2021 11:55 AM UTC
  • 86 views
Hi Chetana,
In the numerator you can include the OR without problem in the PQL statement.
For the denominatior I would set a Filter at the component level (Background filter) with the OR condition.
Hope it helps
Javier
Forum|alt.badge.img+12
Hi Chetana,
I agree with what Javier said.
As a workaround you can also try creating a variable wherein you can write 'OR PQL' query and use that in your component.
It should work.
