How to upload data(in csv format) to studio?
  • Jul 23, 2022 6:16 PM UTC
  • 167 views
  • Celonaut
  • Jul 23, 2022 9:46 PM UTC
Hi Gaurav, on the side panel, select 'Data' -> 'Data Integration' -> (Choose the relevant Data Pool; or create a one one via top right button) -> 'File Uploads' -> Drop your CSV there
Then you can specify/select the relevant columns (e.g. case ID / timestamp / activity).
  • Jul 26, 2022 12:27 PM UTC
That helped. Thanks for quick help
  • Feb 9, 2023 10:10 AM UTC
Hello, I uploaded the csv files and now I have to do the data processing. I have 3 csv files uploaded. How should I do the transformation. Since Execution changed to integrity I do not know how to specify columns etc. Can you help?
