how to set the index
  • Mar 13, 2023 4:37 AM UTC
  • 160 views
I want to add an index to the leftmost column of an OLAPtable that displays row numbers. What procedure should I follow to set this up?
Hi E N,
Hope you're doing well.
Could you please open a ServiceDesk ticket ? They should be able to help you out.
Many thanks
  • Apr 6, 2023 5:51 AM UTC
Hi E N,
Many thanks
@mentor.vucit
Thank you for your reply.
Added a column (A-B FLAG) PQL to the OLAP table on the dashboard that determines A and B. (Not on the data table.)
I want to create a pie chart on the Celonis dashboard that counts A and B and the number of each.
In that case, what formula should I add for KPI and Dimension, respectively?
