How to set auto increment field while creating table in celonis sql
  • Apr 7, 2022 6:58 AM UTC
  • 46 views
How to set auto increment field while creating table in celonis sql, since identity is not working
Forum|alt.badge.img+27
Hi @Amit Singh, do you mean that you want to have an identifier column that increments for every row? You can use the following code in SQL:
SELECT
    xx AS "_CASE_KEY"
    , yy AS "EVENTTIME"
    , row_number() OVER ( PARTITION BY "xx" ORDER BY "yy" ASC) AS "RANK"
FROM "table_name"
In this example you create an incremental ID per Case, ranked on Eventtime. For more information, read the Vertica manual: https://www.vertica.com/docs/latest/HTML/Content/Authoring/SQLReferenceManual/Functions/Analytic/RANKAnalytic.htm
