How to save draft of data pool using API or Pycelonis?
  • Apr 13, 2023 11:23 AM UTC
  • 72 views
I need to schedule publishing of data pool draft. There is the function publish() for packages in PyCelonis but I haven't found something similar for data pool in API documentation or in PyCelonis.
Is there any way I could run saving of data pool draft or adding a new version for unpublished drafts? Is sync of data pool an option for this?
Thank you very much!
Forum|alt.badge.img+3
  • Level 0
  • Jun 22, 2023 1:34 PM UTC
Hi Vira,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly help you.
Thank you in advance.
