How to query a data model to create a data frame? (PyCelonis 2.4.0)
  • Sep 4, 2023 3:05 PM UTC
  • 238 views
Hi there,
I have a Data Model and a Data Pool containing two tables: "REQUESTS" and "ACTIVITIES".
I want to access "REQUESTS" in the Workbench via PyCelonis, select several columns and transfer them into a DataFrame.
The connection could be established successfully:
data_pool = celonis.data_integration.get_data_pools().find('Process-Block')
data_model = data_pool.get_data_models().find('Data Model')
If I now try to output the individual tables with
data_model.get_tables
(source: https://celonis.github.io/pycelonis/1.6.0/tutorials/api_tutorial/04_PQL_and_Python_2/#4-interaction-with-the-celonis-resource-object)
I get as output ID and name of the datamodel, but not the individual tables, as described in the documentation. Also the commands are outdated. Instead of .tables .get_tables must be used in the current version.
Since I can't display the tables, I also can't proceed with the following function according to the doc:
List all the columns of a Data Model Table
datamodel.tables.find('ACTIVITIES').columns
Questions:
How can I specifically extract data from a specific table / columns of the Data Model and transfer it to a dataframe (Inside the Wokbench / PyCelonis)?
Is there an actual doc for pushing data from / to the Data Model?
I am looking forward to your advice.
  • Sep 4, 2023 3:39 PM UTC
You need to create a PQL() object with the query. With that you get a dataframe. See below.
Also, here you have some documentation - https://celonis.github.io/pycelonis/2.0.1/tutorials/executed/02_data_integration/03_data_pull/
You can NOT push data into the process model. You can update a table of the process model, then reload the process model.
HTH
from pycelonis.pql import PQL, PQLColumn
query=PQL()
    for c in t.get_columns():
      query+=PQLColumn(name=c.name, query='\\"%s\\".\\"%s\\"' %(t.name, c.name))
    try:
      df=tempdm.export_data_frame(query)
    except:
      print("**** Error descargando contenido de las tabla %s desde datapool %s del entorno Origen" %(t.name,dplOrigen.name) )
      flog.write("**** Error descargando contenido de las tabla %s desde datapool %s del entorno Origen\\n" %(t.name,dplOrigen.name) )
      continue
  • Sep 5, 2023 3:45 PM UTC
Hello Guillermo,
Thank you for your answer and the reference to the tutorial. It is extremely helpful.
  • Sep 6, 2023 6:01 AM UTC
Hello Guillermo,
My pleasure!
