How to properly model multi-value attributes in Celonis data model?
  • Aug 27, 2024 10:37 AM UTC
  • 220 views
Hello everybody,
I have a data model in which I need to manage one of the case attributes that can have multiple values simultaneously for a single case (i.e. a multi-value attribute) and I am wondering about which is the proper why to model it.
In other DBs and DWHs, I usually model this situation with an additional table linked to the main master data with an N:1 relationship (N records for each master data record), but if I do such thing on Celonis and then connect the master data table to the Activity Table with a 1:N relationship (N activity records for each master data record), when I try to display the Throughput Time by the multi-attribute values, I get the infamous "No common table could be found" error message.
Which is the recommended way to model multi-value attributes in Celonis data model creation?
Thank you, best regards,
Andrea
abhishek.chatu14
The options available for the same are PU_Functions and Bind
https://docs.celonis.com/en/bind.html#idp612421
  • Aug 28, 2024 11:29 AM UTC
Hello Abhishek,
thanks for your input: I have checked the link you shared and the examples described, but I was not able to find a correspondence with what I need to perform.
The concurrent usage of PU Functions and BIND is useful to aggregate data over tables with a 1:N:1 relationship, like in the image below (screenshot taken from official documentation):
My situation with multi-value attributes involves an N:1:M relationship between the involved tables, as in the schema below:
The goal I would like to achieve is being able to create a dropdown filter based on the muti-value attribute (the color in this example) and then calculate the Average Throughput Time based on the cases which fall in the color selection.
In the example above, if I select in the dropdown the values [Red, Yellow], this will imply the selection of Case 1 only, and then the Average TPT should be 15 days (from 10/8 to 25/8).
On the other hand, if I select in the dropdown the values [Red, Yellow, Pink] or [Red, Orange], this will imply the selection of both cases, and then the Average TPT should be 10.5 days (average between 15 days of case1 and 6 days of case2).
I can't figure out how I can achieve this result using PU Functions and Bind.
Can you please elaborate a little bit more? Any suggestions will be highly appreciated.
Thanks very much, best regards,
Andrea
