How to measure time between events and get specific cases
  • Feb 4, 2022 8:38 PM UTC
  • 82 views
Hi there,
i'm farely new to Celonis and struggeling with some basics.
I'm trying so get the time between events (not only directly followed).
For example:
  • i have events A, B, C, D, E
  • time between B and C should be less 1h
  • goal: get all cases to which this applies
I really tried to figure it out, even with OLAP tables, but i think for something this basic there has to be another way.
Thanks in advance, looking forward to your answers.
Steph
burim.hoxha
  • Celonaut
  • Feb 7, 2022 1:04 AM UTC
Dear Steph, Kindly note that we are currently reviewing the questions raised and have already engaged additional Celonis resources on this. Your patience and understanding are highly appreciated.
  • Level 3
  • Feb 7, 2022 10:57 AM UTC
I think you can simply do a selection on throughput time. Select the 2 activities and the limits on the time that you want to see.
  • Level 1
  • Feb 7, 2022 1:10 PM UTC
Wow i really didnt find this before, sorry i'm new to celonis. Thanks a lot for the quick support.
