How to make the Direct connection to Intersystems Cache working?
  • Jun 17, 2022 8:44 AM UTC
  • 110 views
I have been able to connect to our SQL server and retrieve the tables I need through a direct connection. However, when I try the same for the Intersystems Cache database I run into an error.
imageThe system administrator can see that I pass through the firewall, so that's not the issue. I have the feeling that is has to do with the obligatory Cache namespace, when I setup a ODBC connection myself it only works when this field is properly given.
image.pngI expected it to work when I configured it like this but it provides the error message showed earlier within a second.
image.pngAnyone any ideas on how this could work?
  • Level 0
  • Jun 19, 2022 11:27 PM UTC
Dear Pim,
Thank you for reaching to us.
In order to be able to assist you further, we would suggest to send an email to servicedesk@celonis.com with detailed description.
We will gladly assist you.
Thank you in advance.
